ORIGINAL: riadh01
<div style="margin: 0in 0in 0pt"><span style="font-size: 9pt">Is there a way to trigger an on/off switch to act with the throttle rpm range? Switch on, say up to 3000rpm ,off ,above 3000rpm.This is particularly useful when you install an on board plug igniter via this switch. I have tried throttle p mix with an aux channel in combination with EPA for the aux ch to limit itstravel but thisdidnt seem to do the trick. Any suggestions here. Cheers</span></div>
Ithink you can set something like this using the fuel mix option in the radio. Go back to model type and tell it you have a fuel mixture so that screen appears under your model setup.
In this screen and the way the mix is working Ihave: (ignition is in ch.6)
H: 50%
L: 0%
ACC: +100%
OST: 0%
This gives me what apears to be a "on" for channel 6 ignition when at idle that then will quickly be off at about 1/4 stick travel.
