RE: stampede spar gear kepts going bad
probably wouldnt hurt to open up the diff and check it out. unless you removed the diff itself, it has one. Check the bearings and make sure they spin with ease. Theres really nothing else..you said you know how to check the mesh. maybe check the meshing of all the other gears. Perhaps the gear box is cracked or out of line.
