RE: does the avalanche clutch bell have bearings on it????
I actually had ordered two kits, so I have an unopened one. Here's what ca get:
flywheel collet
flywheel
3 clutch shoes w/ spring
flywheel nut
clutch bell
2 bearings
3 small washers (spacers for the clutch shoe (go between flywheel and shoes on flywheel post)).
A few different size washers for spacing (remember or write down how yours came apart)
a black spacer/tube
and allen head screw
I would assemble it, check to make sure all looks well and di-assemble and put locktight on threads (removable type, thinks it red color)).
Also, go w/ aftermarket bearings
use locktight on engine mount/chassis screws once you paper test the gear mesh.
