RCU Forums - View Single Post - High speed needle question
Old 05-21-2010 | 11:03 PM
Lnewqban's Avatar
Lnewqban
Default RE: High speed needle question
The best solution is to replace the O-ring.
That piece of silicone tube needs to be a little longer than the distance that separates the step of the needle and the valve body after the engine has been tunned.
In that way, the silicone will compress and will avoid air leakage.
For my engines, the silicone grease has been more effective; see this thread:
http://www.rcuniverse.com/forum/m_93...tm.htm#9359588
Your problem may not be valve air leaks, though.
