RCU Forums - View Single Post - dead engine??????
Old 05-22-2010 | 08:21 AM
jerdavis's Avatar
jerdavis
Default RE: dead engine??????
Sparkey,
Also:
Sometimes you must have the throttle opened slightly, to the fast idle position or more, to get them to even fire.
You might also check the spark plug gap. Should be: .020"-.025".
Check that the spark plug is not broken of fouled.
Check that the spark plug wire is properly attached to the spark plug.
JD
