RCU Forums - View Single Post - About wing lift
Thread: About wing lift
Old 11-30-2002 | 11:03 PM
FHHuber
Banned
Default About wing lift
The mixed up mess above, is just going to confuse a lot of people, as it says just enough to cause confusion, not enough to clear ANYTHING up. If it were presented properly... it would take about 600 k of ASCII text. (2 k is one double-spaced typewritten page)
The normal simplified explaination of how a wing produces lift is adequate for a basic understanding of flight. We present the simplified Bernouli explaination for the purpose of explaining that you need AIRSPEED to have the wing "create" lift. Inadequate airspeed and/or excess angle of attack means the plane falls out of the sky. (when the wing stalls)
The extra details, which are not needed to give a basic explaination of how a wing works, are ignored when using a flat bottom, high lift airfoil as the introductory example of how a wing holds a plane in the air. This common practice is not an intentional deception... its just an attempt to not overload a beginning R/C pilot with unnecessary information.
You want a PARTIAL explaination of what's missing? Go to: http://www.allstar.fiu.edu/aero/airflylvl3.htm
The full description of how a wing works takes the average Aeronautical Engineering student a couple of years to get right...
