RCU Forums - View Single Post - Sebart Wind 110
Old 05-23-2010 | 06:36 PM
  #879
mdjohnson's Avatar
mdjohnson
Default RE: Sebart Wind 110
Hello Bedowinn
I am about to start my Wind 110 build. I am curious if you are using 10S or 8S batteries? Also could you explain your decision to not use the third bearing in the plywood bulkhead? I am planning on a 5000mAh 8S setup with the Scorpion 4035-250. I am going to do the same thing as you and use my dremel to open up some cooling for the motor.
Cheers
MJ
