RE: engine cuts on landing approach...
A rich LSN will cause the engine to slowly lose RPM until it just stops, and also will cause rough transitions. You could have your idle set too low if it's a fairly new engine (hence my questions above) or you could be using the wrong glow plug (too cold).
