ORIGINAL: VENOMOUS
The GPV uses 0.5 Module metric pitch gears. We offer pinion gears for 2mm and 2.5mm motor shafts. You can also convert the gears over to 64 or 48 pitch if you can work out the spur gear mounting situation.
We need metal sprocket and spur gear since the nylon plastic ones break easily. Can you guys at Venom please make some metal spur/sprocket's so we can be done with the plastic junk? Thanks.
