RE: New CDI - opensource project JMJ and Bigboat
Charlie, I am going to download your code and compile it.. Was there a reason you switched it back to firing at the leading edge instead of leaving it the way it was? If I read the code right, It is almost a duplicate copy of our old code...but I'll try it.
I was successful at adding the test routine back into Nyemi's code.. I was getting confused with the routines and sub-routines calling different instruction lines. I think I understand most of what I did now...hopeing it all works so I can erase the 15 other copies of code for the chips..too many on my hard drive, and it's getting tough naming them all different to tell them apart.
John
