RE: New CDI - opensource project JMJ and Bigboat
Hey Guys,
This is the reason for the change. With the test function and the pullups enabled when powering up the board the test function is entered. The only way I found not to do that is to disable the internal pull up resistors. For the when the timer board fires that was the only way I could get it to work with the internal pullups disabled. I will play around with it some more.
