RE: Flair DR1 Manual
on mine i put the servo wires inside a piece of brass tube running down the left rear cabane. worked out well.
on the gas engine i tried a 1.6 and it wasnt enough to fly it. this has a huge amount of drag. but i also weighed in at 17 lbs if i remember right. ended up with a supertigre 3000 and it was enough but no extra. if i was to do it again i would either set the firewall back enough for a g-38 or use a moki 2.10
