RE: Flair DR1 Manual
I have for the test flight just fixed the wires down the outside surface of the rear struts, unless you look you cannot see them, small hole in the wing and a small tie wrap top and bottom, leads passing through the lower wing
I have an RCV 1.30 in mine which hopefuly will be more then enough.
I have the Flair Hannibal which is larger and heavier and this flies fine on a 1.20 four stroke.
Will find out Friday morning when i test fly it, at least I have 250 metres of tarmac runway to take off from.
