RCU Forums - View Single Post - Engine/Throttle curve setup
Old 07-20-2003 | 09:47 PM
simon109
Default Engine/Throttle curve setup
Just a quick question, If I set my engine up using Headloaders and get that running right, then set all my pitch curves in each mode etc should it be a question of just adjusting my throttle curves to get it flying right/smooth with the correct headspeed, I shouldn't have to adjust engine or pitch setting again or should you ?
Also when using headloaders does it matter what throttle curve you have should I just put 0 25 50 75 100 to set the engine?
Simon.
