RE: CARF CT-114 Tutor 2.6m Build thread
Jeremy
No, I have a Competition in it. Only reason over the Evolution is the 7 channels (its an older version) rather than 6 channels.
I would not use a Sensor or Gemini in a large aeroplane as they are just switches, the PB units boost the signal and screen the Rx.
I have each aileron, elevator and flap on a channel and the rudder and nose steering share because no reverse is needed. That is the 7 channel on the longer leads, I then run throttle, brakes, smoke and gear + Doors directly through the RX. I don't use a sequencer I use servo slow on the DSX-12 to sequence the gear/doors. The New PB Cockpit could be used to save a channel
Dave
