ORIGINAL: Planejaw
I agree with moving the CG back, particularly since I went with the fuselage mounted gear...which really moves the CG forward. The difference in CG caused me to add three-clicks of up-trim when moving to the fuselage mounted gear. Might try to fly it tonight...but supposed to up near 90. May be close to sunset or over the weekend. As with everything else, the simpler, the better!!
I know I've got to richen up my high-end needle on the Fuji 34 a little, because it's so warm. She's set at the factory recommended settings, with the high needle opened up about 1/8 turn to help keep things cool. We'll see how it goes and I'll give you an update tomorrow.
John from Portage, Michigan
No, no, no! You want to lean it if you're compensating for the temp!
The warmer, less dense air needs less fuel to burn properly! Cold, dense air is looking for more fuel....
