RE: NEW 92
Wow! You guys should see what Larry Wolf of Jet Hangar Hobbies is doing with one of these ASM A-26's! He is totally scaleing it out with every detail you can imagine. He has pulled all the covering and glassed all the wood structures, redid all the control surfaces to make them very scale and glassed the bottom of the plastic fuse. Made a new fiberglass eight gun nose and tip tanks! It will be an A-26K Counter Invader as used in Veitam. He has not posted here for awhile so I had to spill the beans! I almost bought one too after seeing it. Should be ready later this summer. Electric powered with scale props.
This is just a pic of a plastic model I found on the net that is the same.
