RCU Forums - View Single Post - HK Small Bolt Hydro same as HOTR
Old 05-27-2010 | 01:24 AM
dhoyt7141
Default RE: HK Small Bolt Hydro same as HOTR
ORIGINAL: nick 30
if i get another one, then the motor would be moved back about 10mm-15mm so the batt can be moved back aswell, it was to nose heavy for me
everything inside still worked (when it all came back) because it was waterproofed
Thats good. What did you use for waterproofing? And what battery were you using? Also, was it a stock prop?
Thanks!
