RCU Forums - View Single Post - HK Small Bolt Hydro same as HOTR
Old 05-27-2010 | 01:55 AM
dhoyt7141
Default RE: HK Small Bolt Hydro same as HOTR
ORIGINAL: nick 30
i used corrosion X on the PCB's in the rx and servo, a dab of marine grease on the gears inside the servo, the speedo was already waterproof, i stripped the batts packaging and let them dry out for a week
it was all stock apart from the servo, rx and batt, the batt was a 2.2a turnigy 3s and aslo tried a turnigy 3a 2s
Wow thats a lot of work! My batteries are still stock and my servo is stock from how I got it!
Did you notice a difference between 3s and 2s in terms of speed?
