why did you get the yg? One of the huge perks is that you can save trims, atvs, timers, and even mixing individually for each model. the 6x has a 6 model memory. there are also 4 programable mixers. meaning, let's say you wanted to mix some aileron in with your rudder to get rid of that annoying roll effect. you could turn it on, and set how much it mixes. it is fully perportional, not not just off and on. all of that is unique to the particulatr model you have. also, another pig perk is that you can switch inbetween pcm and ppm (also called fm) which allows you to go from one to the other without buying a new radio. i have a futaba 8u, and i would not go any other way. Futaba stopped making them, and started making the 9c. the only difference is that the 9c has 1 more channel, and you can assign any channel to any stick, switch, or knob in case you are into battle bots. you can get a used 8u for the price you bought the 6yg for. buying a radio used is not a bad idea. they have no moving parts, nothing to wear out. they are jsut as good new as they are used. If you buy it from a guy who is getting a 9c, you can ask him to order it on the requency you have because they have a thing called a tx module. it contains all the transmitting stuff so you can switch frequencies just by swapping this little thing. you don't have to send it in to do it, and it is perfectly legal. it is just like changing out the entire broadcasting system in your yg. they are really the way to go. when you want to put on a gyro, have to mix in some controls to get rid of nasty habbits, want flaps, dual rates, anything, you need a comp radio. the cap 232 i fly now would not be possible without it. i sold my old 6x because it wasn't enough for this thing, so if you ever get into something like this, the yg wouldn't cut it at all. all the mixing would have to be on-board which is expensive and will weigh a lot. also if you ever want to put somebody on the buddy box, you can select which channels he has control over, and the programming for that model (ie all the stuff i mentioned above like atv, mixes, trims, whatnot) are mixed in with the inputs from the slave so that the all the mixes etc. carry over. the only thing that doesn't is channel reversing. it is also a more powerful radio than the yg. strongly reccomend you check out this website:
http://www.futaba-rc.com/radios/futj80.html . whatever yoiu do though, don't buy their campac. you can make your own, i would be happy to give you the diagram. they charge about $30 for it. it costs you $5 to make.
