ORIGINAL: gi1mo2
Next, I might go for a 500 or 600, but as soon as you change size, parts are no longer compatible, including batteries.
That is generally the case but my size up heli is a Gaui 550 which uses 2 x 11.v 3S1P batteries which is what I use in the Blade. Flight times are limited onthe 2200mAh batteries I have however... and 20C are not quite up to the task... you would want at least 30C or higher.
Essentially what I am saying is that I use my 6 x 2200mA Zippys that I use in my Blade 400 to fly my Gaui 550 for 3 flights.
Just a point to consider.
