RCU Forums - View Single Post - BFM 80 single Cylinder Engine with gear
Old 05-28-2010 | 01:06 AM
mustangrosen's Avatar
mustangrosen
Default RE: BFM 80 single Cylinder Engine with gear
Yes, I think its possible to use in a CARF Mustang.
Three Blade shure. - with the 1:1,6 ratio
Four Blade -  with 1:1,6   - I don't think so - the three Blade is a 26 x 20" - so you'll have to use a 24" 22-24 4 Blade   ... -probably this small diameter  looks silly on that machine.
maybe with a ratio of 1:1,8 or 1:2 . . .    ?
-a ME 109 was flying with that  1:1,6 youi se above. The pilot says: half throttle is enough - the full throttle is for fun! - But it is damaged in a start run by a pilot -mistake.
http://www.rcmovie.de/video/48f80f0d...rschau-Trailer
The price is 800 Euro.
The BFM 80 must be here at  Heger Technik to modify the housing for  the Gear-bracket.
You can get the system by:  www.heger-technik.de
