RE: Hobby Lobby Sr. Telemaster - Help
It looks fine so far.
Try putting some greaseproof paper or thin plastic sheet between the plan and the structure, that way the plan won't stick to the airframe and you'll be able to use the plan again if you need to repair the model.
When my IT Guru turns up I'll upload a few pictures of my Barn Door Wing Senior Telemaster Build. All of the main components are built, I only need to build a flap and an aileron, to cover the model, and to install the radio and engine.
I hope to display the model and the rest of the Telemaster range at a flying event on Saturday 26th June. It's a good job that we have a Bank Holiday on Monday and that this coming Saturday is forecast to be wet. So it looks like it's D-25!
Wish me luck.
