RE: OS 120 AX ON PIPE
Yes, you maybe making more power than the cooling fins can shed while on the ground. In flight the engine will have a better supply of cooling air but may still overheat if you run it at full throttle all the time. Maybe a colder plug or lower nitro will help to contain the thermal runaway you have here.
