Set Up Flapperons procedure
Could you please advise me with the procedure to set up flapperons to a model airplane in the Aerofly Pro De Luxe for Mac Os X 10.5 and a Futaba 6EX transmitter?
what I want to obtain with the function of the flaperons is that both ailerons move downwards when I flip the switch of channel 6 of my transmitter
I have been trying to make it work, without success
In order to obtain the flapperons to work, first I activated the function FLPR in my transmitter, later I fit function FLTR to 25% with switch of channel 6 activated (up) and to 75% with the same switch deactivated (down)
In the main window of the Aerofly program, menu CONTROL, I have tried assigning to the right aileron to the channel the 1 and left aileron to channel 6
So far, when I active the switch corresponding to the channel 6 on my radio, the ailerons move in opposite sense
I have tried to revert the sense of channel 6 in my transmitter but I do not obtain the result of which both ailerons move simultaneously downwards
Please help me
Thank you
