RE: ZIROLI F9F PANTHER BUILD
Assembly (cont)
Right wing.
The ailerons got hs-5645 servos and hs-645's in the flaps.
As with the elevator, dubro heavy duty 4X40 ball links on the servo arm and robarts ball link control horn on the aileron.
The flap has dubro's HD 4x40 ball link on both ends.
pic 1:
Dubro HD hinges epoxied on the aileron and TE of the wing.
One long wire is used for the hinge pin.
pic 2-5:
Aileron and flap secured.
Robart pocket hinges on the flaps for easy removal.
One long wire as hinge pin on the ailerons.
pic 6:
Aileron assembly.
pic 7:
flap servo.
pic 8:
Flap deflection of 35-40 degrees.
pic 9/10:
Aileron deflection of 5/8".
pic 11/12:
Tail feathers and one wing done.
