RCU Forums - View Single Post - tuning help!
Thread: tuning help!
Old 05-28-2010 | 11:17 PM
bigdogkanicsar's Avatar
bigdogkanicsar
Default RE: tuning help!
ORIGINAL: skrilla
ORIGINAL: bigdogkanicsar
i agree, humidity means moisture and when heated it creates a lean condition
It has been a while since I ran in very humid conditions, but I'm pretty sure that higher humidity requires the needles to be leaned some, so it in effect creates a rich condition, not lean
actually it's just the opposite. one of the first things i learned in basic engines was that water(moisture) when you spray it in the carb of automobile evaporates creating a lean condition. causing the combustion chamber temps to rise rapidly and break up carbon deposits in the engine. while that's automotive , there is no difference here. water when heated turns into a vapor(air) which causes a lean condition. therefore you need to richen the mixture to even out the addition of humidity(moisture+heat=air).
