RCU Forums - View Single Post - DLE30!
Thread: DLE30!
Old 05-29-2010 | 10:19 PM
  #2839
captinjohn
Default RE: NEW DLE30!
<hr />No solder is needed if you use a pop rivet to plug hole.Or the kindof rivet you peen over. Capt,n
<hr /> EDIT...I read so much about soldering the hole shut so the engine would choke better....I thought you guys was talking about that hole. Another reason I have not seen to many throttle plates with holes. Now after re-reading the prior postings &amp; the following postings I understand. The pop riviet may work...but only on a choke plate....if the hole is in the right spot. Solder would be best.....make sure it sticks good though! Capt,n
