RE: Larger Revolver
Hello Everyone, My Revolver started out with a 91 FX, Bisson Pitts and it was not tail heavy. Alot of great advise regarding the robarts. I installed them after finding the glued and taped hinge line was not the same on both elevators. Having to cut out and replace the original hinges, I replaced them with some pin hinges. Ended up with a large gap from inexperience. But with taped hinge lines, the plane flies great. Incidentally, I have used CA hinges for years and only had one come loose, the rudder, after a multiple cartwheel landing. This plane may be a challenge for CA hinges, since it has a foam main wing, but no problem yet.
