RE: Eletronic engine syncronizer **SUPPORT **
Hi guys!
Any adivce here?
Still having issues with the sync.
I moved the hall sensors over to the other side of the motor as far away from possible to the ignition components as there was interferance.
That helped big time when the motors are at high to mid RPM. The idle down mode now works when one motor dies.
The big issue I still have is that the motors will not smoothly move from idle to higher RPMs. They idle fine. As you move the stick the motors oscillate and then they hit hard in a higher RPM very quickly. The transition is horrible. I have tried changing the sensitivity to the slowest point in increments as you all mentioned and still no luck. All of the other programming is correct as per the manual with EPA's set above 100% also. Do not know what else to do! Could I have a bad unit?
I have this on an ESM 110 with 2 SV26cc's
Thanks!!
