RCU Forums - View Single Post - YS 170 CDi idle changes
Old 05-31-2010 | 07:43 AM
apereira's Avatar
apereira
Default RE: YS 170 CDi idle changes
Hi Jon,
Mine is very steady, never had that problem, could it be too lean? (pump) or you might have a pump problem.
Did you check the basics? Valves, spark plug gap, etc? have you tried to prime the pump and get all the air out of it with a syringe or similar method? Is the pump hose ok?
Regards
