RCU Forums - View Single Post - Remove magic marker and monokote
Old 05-31-2010 | 01:27 PM
ChuckW's Avatar
ChuckW
Default RE: Remove magic marker and monokote
Depending on the marker, either denatured alcohol or acetone. I keep both around. The acetone will also dissolve the old Monokote adhesive, CA accidents and other messes. The only down side to the acetone is that it can loosen the Monokote seams if you get too much on the airplane and it goes where you don't want it to.
