RE: DA-50 wont start
Thanks for the quick reply. I manually opened the fuel admittance needle earlier today, if its the one on top of the carb(inverted engine) while blowing on the fuel line and fuel does comes gushing out of it as long as I manually press down on the fuel admittance needle while pressurizing the fuel line. It appears to work fine manually and doesnt appear to be clogged. It looks like the needle is opened by the metal pin that is attatched to the membrane. Do I need a new membrane possibly?
