RE: YS-170CDI Flight Report
Valves would be my first suspicion. Also, check the line that runs down the front of the engine from the crank case to the pump. Sometimes if that gets a tiny hole in it it will create a lack of power, but then other symptoms will start, but at first it just doesn't turn up like it should.
Arch
