RE: GTM Hanriot Build
Goodtrip,
I did not build any right or down thrust into the firewall. I wanted the prop to be as perfectly centered as possible on the cowl when viewed from the front, with the prop disc parallel to the cowl as viewed from both the side and the top. You will need to use plenty of right rudder during the takeoff and early climbout, but that is not unusual..!
I'm glad to hear that another one of Glenn's excellent kits is going together!! Are you posting any construction pictures on any of the online forums?
Randy
