RE: .12 Rigger Kits for CHEAP!
Mark sells the carbon fiber pipes too.
I've been outside trying to get the .12 and .21 riggers fired up for the first time. Tried the .12 first and the throttle servo mount broke off so I fixed that with some 6-minute but that was after I tried to fuel it up hooking the pump into the wrong line. Seems I had them crossed at the tank. [sm=angry_smile.gif] Yeah, I felt real smart there! I has a lot of fuel in the engine to clear out. Had to swap out starting belts as the little one from Glenn was too small for trying to turn over a new motor.
It took all 24 volts to fire up the .21, boy, that baby is tight when new even with a loose plug!
