You need Part No. 1015, Part No. 1005, Part No. 1006 (2), Part No. 1003, Part No. 1008, Part No. 1036 and Part No. 1013.
Using a T connector, Part No. 1006, you connect using poliurthane tubing 4 mm (Part No. 1003) the One Way Starting Gas Valve Part No. 1005 and a Starting Gas Probe Part No. 1008. You use this to fill the Starting gas Tank, Part No. 1015.
On the other side of the T connector Part No. 1006, you connect the 4 mm Ball-Cock Valve Part No. 1013 for venting the gas tank after flying, for model storage.
On the Starting Gas inlet you use another T connector Part No. 1006, one side to connect the Starting Gas Tank with a 4 mm tubing comming from the first T connector, and the other side to the Fuel Shut Off Solenoid Valve (you need one of this for gas and the other for Kero), Part No. 1036 - S and from the valve, to the turbine gas inlet.
Page 14/61 of a ECU manual is self explanatory.
You can download this manual from:
<a href="http://www.jetcatusa.com/PDFFiles/Instruction%20manual%20V6.0J2.pdf">
http://www.jetcatusa.com/PDFFiles/In...l%20V6.0J2.pdf
BRG<br type="_moz" /></a><br type="_moz" />
