Freeair Blade 3d
Hi all, my first post here and i apologise in advance if its in the wrong section.
I purchased sometime ago a Freeair Blade 3d and have always been a bit concerned about the prop on it. It flies ok at full throttle but at any other throttle position it seems to hang its tail down as if its tail heavy. ive tried all sorts with moving battery etc forward and nothing seems to cure this.
However the prop is a gws 8x4. should it be a slow fly prop of some description instead of a normal prop and if so do you guys have any suggestions as to what prop i should try? its running a 10amp hyperion esc and a hyperion hp-z2205-46 brushless motor. ive tried been using a 3s-1p 11.1v 360mah and 800mah battery.
