Originally posted by Heads_Up
He said the only plane he ever had a BAD flutter issue with was due to a pull-pull system so he is a bit gun shy.
If the pull pull caused flutter than it wasn't installed properly. The advantage of pull pull is that there is a constant pull on the surface at all times. If anything you'd have more chance of flutter with a rod than with pull pull because the rod can flex.
You can use rods but the pull pull is 10x better setup thats why Morris uses them...
