GWS Tiger Moth
Correct. Set up the plane just as if you were going to fly, except leave the prop off. Run the motor until the ESC cuts the motor off. You can vary the speed some... but mostly keep it at high speed.
You only need to do this before the first time the motor is used to fly a plane. You only have to do this with a new motor, and only one or 2 battery cycles.
