RCU Forums - View Single Post - TopCap Pull-Pull Question
Old 07-26-2003 | 05:35 AM
Heads_Up
Default TopCap Pull-Pull Question
Originally posted by rwh
Yep, one advantage to pull-pull on a profile is that is keeps the side of the fuse clean (no control rods) so that the ailerons can snuggle right up to the fuse.
This gives you aileron control in the hover, which is nice if you don't want to torque roll!
I made a mistake on my last Su-Do-Khoi and put the control lines right through the holes of the servo arm, forgot to use the adjusters on that end. I fly the heck out of that plane, and I keep checking to see if the lines are starting to eat through the plastic servo arm, but so far so good.
I did the same thing on my TopCap. The instructions led me to believe thats the way it was supposed to be until I turned the page and saw the photo.
Thought about leaving it, but instead decided to do it right. Went to the hobby shop and bought 60 ft. of control line cable and brass tube for crimps. Cost me less than $10. Small price to pay for knowing it is done right.
Hope your's holds up ... could be nasty
Rick
