RE: Lipo Speed controller?
The issue will be the Low Voltage Cutoff. Essentially you can not discharge your lipos past a certain voltage. The LVC will help keep you from doing this. Novak makes an out board one and there are tons of alarms available to help as well. Of course if you are looking to crank up the voltage then you may need a new one anyway.
