RE: Remove magic marker and monokote
Monokote trim solvent ain't cheep, therefore I keep some in a small squirt bottle like what ya get with CA accelerator. That way you have control over how much you use and it will last a long time. When I'm done with a covering job I wipe the model all down with trim solvent. This cleans up any residue, magic marker lines and seals the seams down. If ya get CA somewhere you don't want it, trim solvent will clean it up as long as you get to it before it goes off. It's expensive, but very good stuff, I keep some on hand at all times and I don't even use Monokote.
