RE: dle 30 won't run
Take out your needles and drip some fuel into them and then put the needles back in your diaphragm is dry and will not pump fuel or a reed it stuck a bit. If you can get at the cab put your finger over the air inlet to seal it and turn the engine over with the ignition off and it should draw the fuel up to the carb. Once you get fuel into it and get the diaphragm wet it shouldn't be a problem any more.
