These are the 4 snap roll inputs...Try each a couple times. See which one you like the most and which one throws the airplane around the best! Get your elevator, rudder, and aileron throws set as high as you can handle.
Right positive- Full up elevator, full right rudder, full right aileron, and full throttle.
Left positve- Full up elevator, full left rudder, full left aileron, and full throttle.
Right negative- Full down elevator, full right rudder, full right aileron, and full throttle.
Left negative- Full down elevator, full left rudder, full left aileron, and full throttle.
Then take each one of those, and use opposite aileron for each of those 4 with full inputs on everything. It's called a snap roll because you're supposed to just "snap" the sticks. Don't hold the input, just for a second.
As far as spins go, just HOLD those inputs from a high altitude and watch her spin down...
If there is any other manuevers you're wondering about, just ask. This is when it starts to get fun...
