RCU Forums - View Single Post - RXT track problem
Old 06-01-2010 | 09:08 PM
sick6stang
Default RE: RXT track problem
<span style="color: #ff0000">!!!PIVIOTBALLPROBLEMSOLVED!!!
</span>
#1: Set your camber to desired settings. Measure the distance the pivot ball is extended from the arm with a dial caliper. Make metal shims to tighten pivot balls against. You can use brake line for the spacers. Cut off with a pipe cutter close to your size, then flat file to size. Loc-Tite the pivot balls in place.
