RCU Forums - View Single Post - Beginner solderer
Old 06-01-2010 | 09:19 PM
hugger-4641's Avatar
hugger-4641
Default RE: Beginner solderer
Yes you can, just be sure to use the proper guage wire and get the connection good and hot before you start feeding in the solder so you don't get a big lump called a cold joint, which is not a good connection and can cause problems. Are you sure it is actually silver and not aluminum or some old tinned copper?
