RE: dle 30 won't run
Another way to prime your DLE30 carb. Lossen the big screw that holds the pumping section plate on carb. Blow on the vent line of your fuel tank and it should push fuel up into pumping section ...quickly re-tighten the screw. The carb should be able to pump now. Plus you can always squirt a shot of fuel into the intake part of carb. If that does not do it...PM me your phone number. I will call you. Capt,n
