RE: ZIROLI F9F PANTHER BUILD
Miscellaneous.
I drilled the canopy every 3/4" and used #0X3/16" screws to hold the canopy to the hatch.
I used a cheap cut off pilot: in the Fall, I'll put in a cockpit and dress it up.
The aluminum duct tape on the exhaust didn't work. I used acetone to remove the melted glue and then drilled a series of holes between the two exhaust pipes, and used #0X3/16" screws to hold them together. JB weld then was put on each screw head to prevent the screws from vibrating out.
I moved the ECU battery from the nose to the side of the tanks to get the CG (dry state).
This week, while at the CARDS flyin, I hope to get some taxi time in to 'shake out' any 'bugs'.
I had to 're-bind' the plane again to get proper failsafe.
The throttle servo throws need to be put to +/-100%, then bind the receiver, then set the throttle throws to +/-50% and then 'bind' the ECU for min/max throttle/trim and the three aux positions (at least on the JR 2.4).
pic 1:
Canopy screwed on and cheap plastic pilot used.
pic 2:
ECU battery move next to the tanks.
pic 3:
Exhaust pipe drilled and small screws used to hold the two pieces together.
Since the pipe is very flexible, I used a plastic jar lid that fit inside the pipe and then some 1/16" thick brass to prevent from drilling into the inside pipe.
pic 4:
JB weld put on each screw head.
pic 5:
ready to 'rock-n-roll'.
