RE: dle 30 won't run
Ralph, thanks for the offer. You have done magic on two of my G62's I sent you, but I will keep this side carb DLE. Well I got the engine started but it took a while. I added fuel to the carb but it wouldn't start. I added fuel into the two needle holes as was suggested and it wouldn't start. i added gas again to the carb then used my electric starter that I use on my glow engines and after a couple hundred rpm's it started. I ran 2 tanks of gas thru it and started it 4 more times with no issues.
